Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
这个答案有帮助吗?
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
这个答案有帮助吗?
Could it be for any other situations, as I have done all checks and keep the problem.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 2,900
