跳转到主内容
加入维修社区 - 创建账户
Wii 于 2006 年 11 月在北美发布,是任天堂第一款直接支持互联网连接的家用游戏主机,通过 Wii 购物频道 (Wii Shop Channel) 支持在线游戏以及游戏和媒体应用的数字分发。
How do you fix a button that won't press?
The Wii took a tumble a while back, and since then, the eject button doesn't click anymore. Unless its positioned just right, it'll forever try to eject. How do you fix/replace an eject button?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
6个答案
最有帮助的答案
If I'm hearing you right, the console is constantly trying to eject the disc while the button is not being pressed. A solution you may want to consider is removing the button entirely (I'm pretty sure you can still eject the disc from the Wii menu). Try removing the faceplate to get to the button and remove it, to see if that fixes the problem or at the very least to clean out any broken plastic components that may still be in there. Wii Faceplate
Here's the part: Nintendo Wii Faceplate
EDIT: Whoops! Turns out you can't eject the disc from the Wii Menu. I tried through a whole episode of Seinfeld.
Replace the faceplate and its buttons.图片
产品
$19.99
这个答案有帮助吗?
得分 5
添加一条评论
iFixit now has the part you need to repair your Wii (instructions linked to in BWest's answer)
产品
$19.99
这个答案有帮助吗?
得分 3
添加一条评论
the eject button can be replaced but its very small. I use a digital microscope to clearly see the solder points.
这个答案有帮助吗?
得分 1
添加一条评论
clean the buttons some times got dust around
这个答案有帮助吗?
得分 0
添加一条评论
Yes and i need you to fix it
这个答案有帮助吗?
得分 0
添加一条评论
I took apart the Wii and found the disc holder and pushed the egect button a couple times then put it back together and the your set
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 20,179
