跳转到主内容
加入维修社区 - 创建账户
TDK Life on Record A26 发布于 2013 年,是一款紧凑型防水便携式扬声器,具备蓝牙连接和免提通话功能。
What does flashing lights mean?
I turn on the hard switch and push the power button, after three seconds the bluetooth and auxiliary buttons flash. Then device turns off and does not work. Is there a way to fix this? It is an error code but I can not find what it means. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
9条评论
please supply error code
由完成的
The error code is the simultaneous three flashes of the auxiliary and bluetooth buttons. I do not know what that signifies but if you are a computer literate you would understand that it is an error code.
由完成的
Hi, I realized it was an error code but thought perhaps a reset might clear it
由完成的
Yeah, I tried the reset again, regardless. Still didn't help.
由完成的
Hi,
Can't find any info regarding error codes, so am trying to eliminate possibilities. All these questions relate to establishing whether there is a problem with the battery and or the charging circuitry of the speaker.
1. What happens when you only connect a charger that is powered on? 2. Does the correct charging light i.e. red or amber show? 3. If red does it eventually change to amber? 4. Does it work properly when fully charged? 5. If not does it work properly when connected to the charger?
If the above do not point to a problem with the power:
Have you tried disconnecting the battery for a short period and then reconnecting it to see if this clears the problem? Here is a link that shows how to unplug the battery http://downloads.imationsupport.com/lor/...
2 part answer
由完成的
显示更多的4条评论
添加一条评论
1个答案
最有帮助的答案
Hi,
Here is a link that shows how to reset your A26.
http://support.tdkperformance.com/articl...
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tyler Pratt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 19
总计 1,823
