跳转到主内容
加入维修社区 - 创建账户
第四款 Google Nexus 智能手机,于 2012 年 11 月 13 日发布。
Touch Screen Not Working After Back Glass Replacement
I recently replaced the back cover and glass on my LG Nexus 4. It turns on but the screen doesn't sense touch. If I take the back cover off, it works just fine, and if I put the cover on while its already booted, it works just fine. What's the deal? Help?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Ok, I've narrowed it down the the two bottom screws that hold the back cover on. When they are removed, everything goes fine. But still... Whats the deal?
由完成的
Hi, Either the back cover, with the screws in, is compressing something which may be either making it touch something else or it is pushing it loose. An example would be of a connector plug pushed into its' socket then something coming next to it pushing the board so the socket moves away while the plug stays. Also if there is a metal strip or something similar (I don't know, you can see) on the inside of the back cover it may be shorting something out.
由完成的
添加一条评论
1个答案
已选择的解决方案
Turns out the screws on the bottoms holding the back cover on, were just too tight. Loosened them, and problem solved.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dalton Prokott 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 18
总计 408
