跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z3 是一款 2014 年发布的 Android 智能手机,以其出色的电池续航时间和耐用性而闻名。
Vibrator motor not working
So I replaced the screen on my Xperia Z3, then I re-installed everyhting, and everything works except the vibrator motor, I thought maybe I broke the motor so I bought a replacement power button assembly (that has the mic and motor) I replaced it, but it still doesn't work. I didn't replace that tiny little piece that it connects to, because frankly I can't find it for sale anywhere. Do you think that is it?
Any solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi Max
Usually the vibrating motor is on the cable with on/off and volume buttons. If you replace that cable and the motor doesn't work maybe the cable is faulty.
Hope you fix it soon.
由完成的
添加一条评论
3个答案
The vibrator motor is connected to the ribbon cable, Next to the motor there is a connector that gets plunged inn. There is a pink rubber insert that covers the motor that helps with vibration and noise. The motor will still work without the pink rubber insert.
That cable is very fragile, most likly it was damaged during installation.
这个答案有帮助吗?
得分 0
添加一条评论
maybe your screw very tight, loose a bit.
这个答案有帮助吗?
得分 0
添加一条评论
I exactly have a same problem.
I replaced my lcd, then the vibrator & mic doesn't work.. so I replaced the main flexible. The mic is working but the vibrator just stand still.
Still have no idea,
Is there any possibility it caused by the software error or something ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 3,139
