跳转到主内容
加入维修社区 - 创建账户
全新的 N 系列笔记本电脑采用 ATI Stream GPU 通用处理技术,带来更快的性能。这些技术与图形优化套件 Video Magic 协同工作,能够加速多任务处理并实现更高质量的多媒体效果
Error when open a file in illustrator cs2
When open a file that is worked for 2 days, the illustrator show an error box:
Can't open the illustration. Could not complete the requested operation.
Then the opened file has only a blank layer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Thank you buddy for your help and time. your recommendations are very useful. the issue is resolved.
完成的
添加一条评论
1个答案
已选择的解决方案
It sounds like it got corrupted then. I doubt you will be able to do anything to recover it… But at least you have the option to try to save the information from the file using Illustrator Recovery Toolbox. http://www.oemailrecovery.com/illustrato...
Are you working off of a local hard drive or across a network to a file server? You might have some issues with your network if it is the latter.
这个答案有帮助吗?
得分 1
1条评论:
I hope this posts will help you also.
http://yourfriendlyitconsultant.com/2009...
完成的
添加一条评论
添加你的答案
georgecarroll 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 5,340
