跳转到主内容
加入维修社区 - 创建账户
型号 A1418 / 2014 年中 / 1.4、2.7 及 2.9 GHz Core i5 或 3.1 GHz Core i7 处理器
No backlight screen is dark
My iMac is A1418 2013 MF883 LM215WF3 (SD)(D1) 21.5".
I installed new screen display and have same issue
I shine a flashlight at an angle at the display and see the faint image of the desktop and icons. How do I fix the backlight?
Which is it? The CFL's or the power inverter on the iMac 21.5" 2013 model.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
This model uses LED's for the backlight and the power is supplied via a ribbon cable from the logic board.
Review this IFIXIT guide: iMac Intel 21.5" EMC 2805 Display Replacement. Jump to Step 20. Make sure the cable is correctly inserted.
Use a magnifier to inspect the pins of the cable and the socket as they could be damaged. If they look OK, you'll need to do a detailed inspection of the logic board as something has likely blown.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Thuan Tran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,470
