跳转到主内容
加入维修社区 - 创建账户
Samsung NX30 是一款可更换镜头的无反相机。它支持高清视频录制,于 2014 年 2 月 18 日发布。
The flash isn't working!
Alright, I bought this camera about 2 weeks ago and have everything still, used it right out of the box until yesterday, when the flash wouldn't work anymore. I've done all I can without breaking the thing, the button doesn't really work so I kinda have to force it open (which I don't want to do because it might break), and then once I do get it open the flash isn't working. Is it possible I need to take it apart and replace the bulb? If so, I'm not really comfortable with that, but is it possible this could be a software issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hello William, is the flash bulb slightly dislodged? That may be why the flash head does not open up easily when you press the flash button. You can use a screwdriver to remove the screws holding in the bulb and then adjust the bulb and screw it back in properly. Once the bulb is in properly, the flash might start working again, otherwise you may have a dead bulb.
If the flash bulb is dead, this is an easy fix - you can just follow the guide right here: Samsung NX30 闪光灯更换.
All you have to do is get a spare bulb and switch the dead bulb out by unscrewing a couple screws.
这个答案有帮助吗?
得分 1
1条评论:
For further help, here is a link to the troubleshooting page for the specific issue: Samsung NX30 Troubleshooting
完成的
添加一条评论
添加你的答案
William 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 1,259
