跳转到主内容
Pulled Out A Particular Wire
I pulled out a particular wire while installing my disk caddy for my new hard drive. Want to know whether it is vital to operations or not.
Currently Macpro is running normally, and I don't really have the equipment to solder it at home so I want to know whether it's worth getting someone to solder it for me/to obtain a solder for.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
no it's not the fan cable. You can see part of the fan cable at the upper right of the pict. I think that your broken cable is for the isight camera or bluethoot or wifi not sure...try these functions.
这个答案有帮助吗?
得分 2
1条评论:
It's definitely not wifi because that works. I don't really use the other two functions so it's alright for me. Thanks!
完成的
添加一条评论
最有帮助的答案
Well that appears to be the wire to the fan. Stick it back in.
这个答案有帮助吗?
得分 4
3条评论:
Well I would except I'll need to solder it back in. Thanks for the answer though!
完成的
It isn't soldered in the first place, why do it now, Just stop yanking on it.
完成的
Well it used to be attached to something reattachable so it didn't need to be soldered. And yeah. I stopped yanking on it.
完成的
添加一条评论
Lemerise is right. That is your isight camera cable and unfortunately there is no fix for that, I repair on component level with a stereo microscope and it is nearly impossible to fix! Your only option is to pull the glass and replace the cable or buy a used display and selling the old for parts if you wanted. That's it! See within the wire there are 10 strands that are microscopic if 1 of them is not together with the rest it will not work so your working on 2 wires the outer and the inner with 10 and there is four wires total.
这个答案有帮助吗?
得分 3
1条评论:
Well I don't use the camera anyways so it's fine. But thanks for the advice.
完成的
添加一条评论
添加你的答案
Xyilver 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 160
