跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
iCloud locked I need it unlocked
Bought a phone from my friend he said his sister was selling it because she switched to a different phone. (Samsung) So when I got the phone turns out the icloud was locked and he told me she doesn't remember her password and I cant get in touch with him or her what can I do to unlock my phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 133
20条评论
Sell it as parts it is not possible to unlock the phone
完成的
Try taking it to a cell phone and if they unlock the cloud
完成的
i have the same issue ...did u figured how to bypass the lock??
完成的
I have iphone 6s abd i foreget the icloude id and i can not use the phone plz help me to unlock the icloud id and prmant remove
完成的
please eny one help me for my beloved iphone 6 activation lock pm og dm me please
完成的
显示更多的15条评论
添加一条评论
10个答案
已选择的解决方案
There is no easy fix unless you have proper paperwork for the resale of the phone then you can be helped by the apple store. By the way its easier to deal with a second hand android phone than a second hand iPhone.If its locked in icloud its a paper wieght
这个答案有帮助吗?
得分 56
7条评论:
Can you please link some honest services? I've seen so many mixed answers on this subject that I am wary to trust the many many services that are out there. Have you used them yourself?
完成的
There are two ways to remove the iCloud lock, one is contact Apple for help (highly RECOMMENDED!) another way is to perform a hardware exchange, the only way to use the phone is change the entire motherboard, but all your data will lost and the IMEI will also changed. This procedure requires high technic. Also, your Touch ID might not work.
I will not recommend you to "unlock" with some fee at the website, most of them are absolutely scammers, and the other way is they have built some servers to bypass the Apple viration, but this way is risky because you will not be able to update the iOS version anymore and you will lost the cellphone function(include cellular data). Your phone will be absolutely an iPod touch.
完成的
Beware or unlocking scammers on-line with fancy websites, where they post fake feedback from unreal customers. It's not possible to unlock iCloud Activation Lock unless you have correct Apple ID or official invoice from Apple Store.
If you want to know the truth about iCloud Activation Lock, read this: http://geekdummy.com/faq/how-to-bypass-i...
完成的
The IP address / DNS points the iphone to someone's private server. This will get the phone to work, but you will never be able to reset or upgrade the phone after this because highly likely the private server will either shut down or remove access. So if it does work, it is a one time only fix because any time after it will try to hit official Apple servers again, checking for the hardware match with associated iCloud accounts..
完成的
Took mine to the Apple store past Sunday with the Bill of Sale Invoice (I bought it from Ebay) and they unlocked it with no questions asked.
完成的
显示更多的2条评论
添加一条评论
Well, if is indeed your friends sister. They can email Apple and she can have them reset the password, and get into the phone and have it erased
这个答案有帮助吗?
得分 17
7条评论:
She will need a receipt.
完成的
just connect it to iTunes and rest the whole device manually using iTunes on a mac.
完成的
That only works if it was originally set up from a Mac or PC, and it only works if you use the Mac or PC that was originally used to set it up. If the sister still has the computer she was using with the iPhone, she could do that; but shai can't do that on his own.
完成的
Sorry iCloud lock is not tied to the PC's copy of iTunes directly, you still need the original Apple ID to unlock it.
完成的
the old owner (if you know them) can log into www.icloud.com with their credentials and remove the phone from their icloud account. physical access to the phone is not required. however, the phone will not know it's been disconnected until it can talk to the internet.
完成的
显示更多的2条评论
添加一条评论
Here's how Apple says to fix it:
https://support.apple.com/en-us/HT201365
这个答案有帮助吗?
得分 10
2条评论:
How did apple said it should be fixed
完成的
Cole click on the blue link
完成的
添加一条评论
Something tells me it wasn't your friend if you can't get in touch with them.
You've been sold either a phone that's been stolen or lost.
Unfortunately, there's absolutely nothing you can do to remove the old iCloud. So I suggest you try and get your money back. :-)
这个答案有帮助吗?
得分 7
添加一条评论
the only way is to get previous owners icloud password etc... i purchased an iphone 6 from a secondhand retail store and phone was asking gor previous owners icloud info, i paid to try and havd this removed through icloud removal site but this failed as previous owner hadnt turned off 'find my phone'. Real pathetic Apple wouldnt resolve this even with proof of purchase :(
这个答案有帮助吗?
得分 2
1条评论:
The proof of purchase has to be from Apple or a reseller they can trace back the serial number to. Likely a fake receipt or a resellers which also has no validity.
完成的
添加一条评论
here we go tell me why my iphone 6s plus which i used for a while ,anyway i reset the password for my icloud account as i forgot it,which takes 28 days RESET after which i then tried to log back into my fully fixed 6s but it said apple id and password were incorrect i 100% have the correct id: and a new password which works if i use a pc to log in to icloud
i called apple support and was told that the phone i had been using for a year did not have the correct apple id associated with the device yet i have not changed it so now i have a paperweight and its there fault so to sum up
correct apple id:
correct password
my 6s is now a paperweight thanks apple
customer satisfaction ZEROOO
这个答案有帮助吗?
得分 2
1条评论:
You have to know the very first apple id and password it dont matter if u change it on a PC your phone won't know it was changed
完成的
添加一条评论
Apple store unlocks for free as long as you have proof of purchase or re-purchase, bill of sale or ebay invoice or similar. Works like a charm, guaranteed. If one store gives you trouble, ask to speak to a manager or go to another store.
这个答案有帮助吗?
得分 2
添加一条评论
you should reset settings and it will help
这个答案有帮助吗?
得分 1
2条评论:
@meme King, That doesn't work!! do you know what icloud lock is btw?
完成的
cannot remove, sorry.
完成的
添加一条评论
I bought a iphone 6s rose gold from a apple reseller on ebay but when I got the phone and started setting it up i see it had a activation lock on it I have been trying to unlock it for 3 days but still nothing I even contacted apple and they said they can't help me either thanks a lot apple customer satisfaction 0
这个答案有帮助吗?
得分 1
添加一条评论
I pay to unlo my iphone 6splus
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
shai 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 57
总计 145,820
