跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
Why my 2DS does not open?
I have a 2DS and when I power it on the blue light turns on but the screen still remains black. After some seconds it makes a wierd noise and turns off completely. My brother says that it has been exposed to water . Any ideas on how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This is a complete guide for teardown and troubleshooting and can guide you through your fix
Nintendo 2DS
Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
Put in rice for a day
这个答案有帮助吗?
得分 -2
7条评论:
Rice is a food not a tool
完成的
But if it gets wet it will soak up all the water
完成的
@Cozy Rozema, Rice is absolutely useless. It will not remove all humidity, it will not prevent corrosion, it will not remove liquid between components and it will not prevent short circuits. Using Rice as a desiccant is the equivalent of doing nothing.
完成的
You're Both Right - Rice is a fine opening move for consumer water removal, but OldTurkey has a point, it's not going to solve your problems; disassembly will be required.
完成的
@alinorne Kevin - Rice as a desiccant is an old wives tale. Even if you boil it, it only soaks up 2X. Unboiled all it does is make a mess. Your voracity as an answer giver is at stake here, do the research!
完成的
显示更多的2条评论
添加一条评论
添加你的答案
John Hatzis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 302
