跳转到主内容
加入维修社区 - 创建账户
HP Color LaserJet 2600n 是惠普生产的一款彩色激光打印机。
paper feed issue on printer
When printing, just as the paper begins to exit into the tray, the paper jams. It wrinkles the leading edge of the paper. Took it to local repair shop and they thought it was a fuzing issue, but couldn't say for sure less than $118. charge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The fuser is the likely suspect and it is possible that the roller is bad. If the printer has had labels put through it then the likely issue is the glue has got onto the roller hence the jamming. Try removing the fuser and clean the roller with an alcohol based cleaner which should not leave any residue. If the roller is damaged it can be replaced but you would need to obtain a service manual (worthwhile) to enable dismantling. There are going to be you tube videos on aspects of fixing a fuser assembly.
Hope that helps find a solution.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joey Pace 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 23
总计 535
