跳转到主内容
加入维修社区 - 创建账户
内置的 Beats Audio™ 技术为你提供毫无妥协、录音室级别的音乐、视频及游戏音效。它也是一款功能强大的全能机型,配备双核处理器、色彩明丽的 4 英寸清晰显示屏以及领先同级的摄像头。
Cannot get the phone to start
My HTC Desire pay as you go phone has suddenly gone blank. No screen, nothing. I am away on holiday and rely on this to call my elderly mother. Any advice welcome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
Do you get any indication (charge light, symbol etc) at all on the phone when you connect the charger to the phone or if you connect the phone to a USB port in a working PC? Can you try a different compatible charger or USB cable?
完成的
No indication at all. Cannot connect to PC but have tried 2 chargers.
完成的
添加一条评论
0个答案
已选择的解决方案
Hi,
Try the following:
Remove the battery, wait for about 10 seconds, then reinsert the battery.
Here is a video that shows how to remove the battery. The battery only has connections at one end so when you replace it make sure the terminals are in the correct position. Also don't miss it in the video the battery removal is complete within the first 27 seconds .
See if it will charge/start now.
If not try performing a factory reset.
Be aware a factory reset will erase all your downloaded apps and user data . It will restore your phone to a factory default condition. It will be like when you first bought it.
To reset your phone:
  1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
  2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
  3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
Be patient, it takes a few minutes.
If you cannot perform a factory reset due to the phone not responding, unfortunately and obviously the phone is faulty. Perhaps a professional phone repair service may be able to repair it. Ask for a quote first.
If your phone is still under warranty, contact the manufacturer's customer service section regarding a warranty replacement.
这个答案有帮助吗?
得分 3
1条评论:
Thanks, removing the battery worked!
完成的
添加一条评论
添加你的答案
Hilary Patterson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 380
