跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
5C bad drop no touch/copy screens do not work
Hello,
Apologies if this has been answered before but I couldn't find anything that quite matched my problem.
Got in a 5C to recover the data after a bad drop, touchscreen didn't function and there were very faint white vertical lines through the LCD. I tried a new screen, and was presented with a dark blue image (as if not connected correctly). I reseated etc and tried two more screens all of which had the same problem. These screens work on other phones. The original screen still has the same issue if plugged back in. Taking a known good genuine screen from another 5C presents the same problem as the original screen. To summarise : copy screens don't work and genuine screens have no touch on this phone.
I've tried disconnecting the battery and all the obvious solutions. I peeled off the black tape and have examined every component around the connectors and everything appears to be okay. Phone is not water/liquid damaged in any way.
Thanks in advance,
Sam
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Is the phone detected in normal mode or DFU/recovery mode by iTunes when the copy screens are connected?
If you are doing data recovery, I would forget about the copy screens since you have image on the original screens. Troubleshoot the touch lines on the logic board. To get you started, the power for the touch system comes from a chip called U3 on the 5c---it is the display/touch power ic. Look for lines that are SAGE (touch) 5v7 and -5v7. Troubleshoot from there.
good luck---your question was very clear, I am happy to help.
Jessa
这个答案有帮助吗?
得分 4
3条评论:
I've looked up the schematic now - should I test for continuity between the connector and each of the components? How do I test the U3 touch IC?
完成的
Check voltages in and out of u3
完成的
This probably seems like a stupid question, but how would I test for a voltage using a multimeter as it is a BGA chip?
Thanks for the reply!!
完成的
添加一条评论
Check the digitizer connector carefully. It has some issues due to the design that can cause the connector pins to not line up.Be mindful of the digitizer connector since it also has a tendency of bending the pins since it does not have any end caps.
As you can see the connector lacks metal ends and this is what makes it a weak connector. It is easily possible to damage the connector by mis-aligning the digitizer connector
这个答案有帮助吗?
得分 2
1条评论:
Re-inspected through the microscope, there is no noticeable damage to the connector. Both ends look okay. The microscope I'm using does not have a digital camera attached so I can't take a photo to show you. I've checked the LCD connector while I'm at it again, and that too looks like it should.
Any other suggestions?
完成的
添加一条评论
添加你的答案
Sam Murphy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 170
