跳转到主内容
加入维修社区 - 创建账户
Samsung SyncMaster 245B 是一款采用 TFT(薄膜晶体管)有源矩阵的 24 英寸 LCD(液晶显示器)监视器。
Is my panel dead?
Hi ! I'm new to this site, so please forgive any mistake I might make in regards to my description and please forgive my poor English as well.
Here's my issue: my screen (a Samsung SyncMaster 245B) stopped working recently, the blue LED indicating power still lights up, but the panel itself stays black (it usually shows a grey box when nothing is connected to the screen at the very least). So I'm wondering if the panel itself is dead or if it might be another problem.
And I'm also wondering in case of the actual death of the panel, is it worth replacing or should I straight up buy another screen instead?
Thanks for your time and your answers to come ! :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Have you tried the repair solution described ?
Maby it´s just that, a dead resistor in the power supply ?
由完成的
添加一条评论
1个答案
已选择的解决方案
Hey, Sinouhe. Apologies that this comes months after you asked the question. I own two Samsung SyncMaster monitors, both of which had the same behavior you're describing. In both cases, the root cause was a couple of blown capacitors on the power supply board in the monitor. If you have the skills and tools to repair it, you're looking at a $5 repair.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Sinouhe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 1,890
