跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Battery Replaced with a new one from iFixit
Hello Guys, so i bought the replacement kit, and the replace worked well, so i turned on the phone everything worked fine, so 5 hours later the phone goes off and nothing happend it goes on again, and now it wont turn on
What reason can it be??
I thank you for your help
Greetings from Germany
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
@tess, so you've tried charging your phone and it does not work? what have you tried? Are you using an Apple charger or an aftermarket charger?
完成的
try putting the old battery in and see if it will power on.
完成的
i replaced the battery and the phone worked for ~5 hours fine , i just texted a message and the phone turned off, i use original apple charger+ cable, when i had charged up it wanted to boot up and fall into boot cycle again and again , when i stick out the cable the phone does nothing
im very very confused
thank you for your help so far
完成的
添加一条评论
1个答案
已选择的解决方案
I solved the Problem by myself and with the answer of @leevancleef
i changed the battery with the old one again, and now the iphone works fine, i think the new battery has an damage or something like that, so i will return the battery in change of an new on in hope the new replace battery is well
thank you all
Tess
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 117
