Battery Replaced with a new one from iFixit
Hello Guys, so i bought the replacement kit, and the replace worked well, so i turned on the phone everything worked fine, so 5 hours later the phone goes off and nothing happend it goes on again, and now it wont turn on
What reason can it be??
I thank you for your help
Greetings from Germany
3条评论
@tess, so you've tried charging your phone and it does not work? what have you tried? Are you using an Apple charger or an aftermarket charger?
由 oldturkey03 完成的
try putting the old battery in and see if it will power on.
由 leevancleef 完成的
i replaced the battery and the phone worked for ~5 hours fine , i just texted a message and the phone turned off, i use original apple charger+ cable, when i had charged up it wanted to boot up and fall into boot cycle again and again , when i stick out the cable the phone does nothing
im very very confused
thank you for your help so far
由 Tess 完成的
