跳转到主内容
加入维修社区 - 创建账户
HP Compaq Presario C700 的维修信息与故障排除。这是一款 2008 年推出的经济型笔记本电脑,属于 Compaq Presario 系列笔记本电脑。
Scam preventing access to files/documents
My computer has been scammed and i cannot access my files/documents..
message says the files have been been protected by a strong encryptioin with RSA-4096 ..
I understand this is a scam that has been going for a few years...
What can i do ???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Mary is there two problems ? the overheating power adapter and the ransom ware . As for the power adapter how hot is it and does it get that way when you first turn it on or does it take some time to heat up? Does the computer seem to run hotter as well ? Does it seem to be harder to plug in to the laptop?
The ransom ware is an ongoing problem that is a hard fix . The fixes that are out right now are not that effective and can end up with you loosing all your info. what I would suggest to you is buying a new hard drive and having a new OS installed ,start fresh and setting the old one aside until a fix is found to rescue you info safely. If there was not any important data on the computer or you were smart and had it all backed up, you can just reformat it and that will wipe the drive clean and a new fresh OS can be installed. At this point in time there is no safe fix that can guarantee getting your info back
Hope this helps
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mary Brigg 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 370
