跳转到主内容
加入维修社区 - 创建账户
针对第一代雪佛兰 S-10(4WD T-10 型号)Blazer 的维修指南和支持。这是一款基于 S-10 皮卡的中型 SUV,与 GMC Jimmy 关系密切。
fuel pump pressure issues
my chevy s-10
fuel pump doesnt seem to be pumping the right amount of pressure?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
It can only be a few things. If you have to guess at all, start with the fuel filter first if it has been a while ago that it has been changed. If it is full of dirt, pull the pump and replace the sock next. The next item to be the culprit is the pressure regulator. Fuel pumps either work or don't most of the time. It should only be replaced if everything else checks out. Best bet is to obtain a pressure gauge and verify you have or don't have the right pressure.
这个答案有帮助吗?
得分 0
1条评论:
I have rarely had to replace a fuel pressure regulator. I do agree with the filter. Fuel pumps Often times will work and function but not provide adequate pressure for the system. I've Replaced many that ran poorly due to the pump Running but not at peak performance.
由完成的
添加一条评论
添加你的答案
billy a 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 1,119
