跳转到主内容
加入维修社区 - 创建账户
Dell Precision M4600 是一款 15.6 英寸笔记本电脑,属于 Dell 移动工作站系列,具备强大的处理能力,由 Dell 公司于 2011 年至 2013 年间发布。
Screen Flickering when start from Cold
My Laptop Screen flickers with fuzzy pixels when it start from cold and still flickering until it warm up then i should close the lid and open it again to disappear and back to normal state.i attached external monitor to check if this from graphics card but external monitor worked fine without any problem.i want to know if this problem from the screen itself or problem with the motherboard?
this video show how it`s flickering.it`s not my laptop but just for clairfying the problem.
https://www.youtube.com/watch?v=ctHn8P-2...
Thanks in Advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
hi ,
I disabled optimus nvidia option from bios and this solved my problem.thanks for your help :)
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
mahmoud eldeep since it displays properly on an external monitor, I'd exclude the motherboard/GPU. It is easily possible that you are having issues with the LCD. I'd start there.
这个答案有帮助吗?
得分 2
9条评论:
Thanks for your fast reply. but is there any explanation for this phenom? is cold can effect on the screen and make it flickering like this?
由完成的 分享
Yes it can. coils,caps and resistor as well as transformers can have cold solder joints that may close during warm up.
由完成的 分享
I`ll replace my screen and feed you back with the results. Thanks Man
由完成的 分享
I have another Dell Latitude E5520 with Screen of 15.6” HD (1366x768) Anti-Glare LED. I exchanged the two LCD and my screen works fine till now on latitude without any flickering from startup and latitude screen works fine too on my laptop without flickering at startup too till now.my screen is 15.6" 1920x1080 HD Ultra Sharp Anti-Glare LED.what may cause this problem??!
由完成的 分享
the problem not from the monitor as i replaced it with another low resolution one (1366*768) and it did not show up the problem.i think it`s something related to power input from graphics card to the monitor as FHD monitor consumes alot of power than the HD monitors.but i still can`t determine which part i should replace.
由完成的 分享
显示更多的4条评论
添加一条评论
https://okadtech.com/dell-laptop-screen-...
Hope this will help you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mahmoud eldeep 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 10
过去 30 天: 43
总计 9,356
