跳转到主内容
加入维修社区 - 创建账户
BLU Studio 5.5 于 2013 年 10 月 1 日发布,是一款无锁 Android 智能手机,拥有 D600(单卡)和 D610(双卡)两种机型。
Battery and EarBud Sound
Hello. I've struggle using this product for the past two weeks. When I use this phone without the adapter for about two minutes it goes from one hundred to one percent in just under five minutes it completely dies. Ear Bud sound only come from one side. I've tried the same Ear Bud on a different phone and it works perfectly fine. What can you or I do at this point?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Do you have a case on your phone this can sometimes keep the jack from being plugged in all the way.It usually plays on one side only if its not plugged in all the way.
这个答案有帮助吗?
得分 1
4条评论:
I tryed it with and without the case, same issue occurs.
完成的
is the plug going down till its flush with the rubber on the end of the jack there could be something stopping it from plugging in all the way . lint in the jack or dirt
完成的
Its possible it could be caused by dirt or lint. What is the best, non lethal way to clean it? Especially the amount of room the "jack" provide. In terms of battery the one provided with the purchase of the specific model.
完成的
shine a light down the hole see if you can see anything and if you need to clean it a toothpick works well no shock there
完成的
添加一条评论
添加你的答案
Vinay Sewkaransing 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 456
