跳转到主内容
加入维修社区 - 创建账户
NeuTab N7 Pro 平板电脑配有前置和后置摄像头,搭载 7 英寸显示屏,运行 Android KitKat 系统。
Device will not charge.
I received the device in early August and in December it stopped charging. We checked the charging cord and tried other cords but nothing happens when it is plugged in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
try wiggling the charge cord around when its plugged in . Does the port move at all or does it seem solid check in the port for fuzz or dirt sometimes stuff gets into the port and stops the process
由完成的 分享
添加一条评论
2个答案
At the same it depends on your device, but assuming its a cellphone... probably the charging port its self needs to be replaced, or the battery.
这个答案有帮助吗?
得分 0
2条评论:
It is a tablet sold under the brand name Neutab N7 Pro. (7" Quad Core Google Android 4.4 KitKat) purchased from Amazon.com and received in early August 2015. It was in use less than 5 months when it stopped charging/working.
由完成的 分享
Do you connect your tablet using Turbo Charger? if that makes sense
由完成的 分享
添加一条评论
Same thing happened to both my grandsons' N7S Pros. I had to open the tablet (see Youtube for instructions) and carefully inspect the underside of the circuit board where the charging jack is mounted. The center pin had broken loose and needed to be carefully resoldered to the board. This procedure may be beyond the capabilities of many users. You'll need soldering skills and proper tools. If you're not comfortable with this procedure it's probably best to contact a repair center.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marion Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 22
总计 1,316
