跳转到主内容
Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
57 个问题 查看全部
Poor battery life due to water damage
I've got a water damaged Sony a2, that's the Japanese version of this phone. It's been water damaged due to use in the shower. The phone seems a bit buggy apart from short battery life but I think this may be due to a broken power button. Is it worth trying to fix or will the water damage effect other areas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Lex Man, "short battery life" most likely not related to a broken power button but most likely related to water damage. You do want to start with a new battery. Also, make sure that you clean the phone completely if you have any inclination on keeping it for a while. If you do not clean it properly it will continue to corrode until it is damaged beyond any reasonable repair. I'd suggest that you clean it using this guide. It was written for an iPhone but all the points are pertinent to your phone as well. Use these guides to work on your phone. After that, replace the battery.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lex Man 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 338
