跳转到主内容
加入维修社区 - 创建账户
Xperia Z1 Compact 是索尼推出的高端拍照手机。它与 Xperia Z1 型号类似,但体积更小、价格更低。其主要特色是搭载了一枚 2070 万像素的传感器。发布时有白色、黑色、粉色和青柠色可选。 可通过型号(D5503)识别该设备。
Screen not working after replacement
Hello I have Xperia Z1 Compact with a broken screen. I have ordered a replacement screen from ebay. When I connect the screen to the phone and turn it on, nothing happens. I know that the phone works because I hear boot up sound. Also when I press unlock button and then volume up/down keys I can hear the volume change sound. If we assume that the replacement screen is working, what could be wrong with the phone? Is there anything I could do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have a similar problem, i tested the new screen and was satisfactory, however after installing it with the gasket it failed to fire up
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
The LCD ribbon cable could have been damaged during installation. Make sure the lcd connector is connected prperly. You might have a defective part, eBay parts are not always the best choice....
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the answer. Unless the ribbon was already damaged I doubt I damaged it. Connector is easy to access and I was gentle. I was wondering what chances are there that there is something wrong with the phone itself. For example that metal panel below the display (is that heatsink?) seems a bit detached now. Could a connector itself be a bit detached from the board?
由完成的 分享
添加一条评论
添加你的答案
Ivan Savu 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 12
总计 1,366
