跳转到主内容
加入维修社区 - 创建账户
4.3 英寸宽屏 LCD 显示屏,搭载 333 MHz 处理器。型号为 PSP98510。维修此设备需要用到常见的螺丝刀和撬棒工具。
Issue with power fuse
Hi there, bit of an odd one. Perhaps someone with a bit more electronics background could advise what the issue is here.
Issue: PSP doesn't power on. Charges fine.
On investigating the issue I checked the power fuse (Marked TB) with a multimeter to see if that was the issue. The fuse showed continuity so assumed it was fine.
Then by accident I checked the fuse again while a battery was connected and as I test the fuse with the multimeter the PSP powers on.
Is the fuse the issue? Seems when I bridge it that it powers on automatically, but why if the fuse is giving me audible continuity when I check it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Also when I set the multimeter to ohms to check the fuse it shows as 0.00 as it should.
由完成的
添加一条评论
2个答案
已选择的解决方案
Found the issue, the ribbon cable between the power switch and the mainboard was faulty. When I was bridging the fuse it was somehow triggering the power on sequence bypassing the switch.
Swapped the ribbon cable with one from another faulty console and worked perfectly.
这个答案有帮助吗?
得分 3
1条评论:
Spot on. just finished fixing an old psp 200x with the action key ribbon and switch board from a decommissioned psp 300x.
由完成的
添加一条评论
ainda nao testei mais levei a um tecnico que me indicou esse problema (troca do flat) ainda esse mes vou comprar e trago nova resposta
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brendan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 44
总计 6,898
