cant charge my table
I cant charge my table, do your company sell one that will fit my device
the recver end of the charger is pushed back in not allowing the power cable to make contack . it needs to be pused back in place to make contack agend.
这个答案有帮助吗?
How do you pull the receiver end back out
How do you pull the charger piece back because mine is pushed back
How do I pull back out or where can I send for repair
do you have to open in up
My tablet will not charge. The end of the charger will not connect to tablet?
这个答案有帮助吗?
I am having the same problem! What is the answer?
I would like to have this uniy replaced there is something wrong this is pnly about the twenty time this has happened i am tired of this.
这个答案有帮助吗?
tablet dose not response or turn on or off
这个答案有帮助吗?
My charger wobbles when it is connected to the tablet and the charger end does not go in completely. It won't charge. What gives?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,701
10条评论
Mine will not charge, it's only 2 months old
由 Paul Case 完成的
Also when I try to turn it on a battery symbol with a triangle in it appears
由 Paul Case 完成的
I have the exact problem, is there a solution? Besides buying a new one.
由 Yvonne Cowan 完成的
I am also having this problem, getting very frustrating!
由 lulalor68 完成的
Mine and my daughters will not turn on either and both are only 3 months old!
由 Carlo Stokes 完成的
显示更多的5条评论
