跳转到主内容
初代Xbox是微软推出的第一款广受欢迎的游戏主机。它的外形设计非常易于辨认:黑色外壳,XBOX字样醒目的标在机身上盖和正面。使用常见的工具即可进行方便的维修。
Why is My Xbox showing Error Code 01?
My Xbox is flashing a red/green light and showing Error Code 01. Can you tell me what this means and how I can fix it? it is the original Xbox
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi louiserom70,
you might want to check this page for further information:
(e.g. What is the number of (red) lights that your ring of light shows? )
https://xbox-experts.com/errorcode/E01/0...
Regards and good luck/don't give up
这个答案有帮助吗?
得分 2
3条评论:
Thank you :)
完成的
hi again but it doesn't make any difference I mean still flashing red
完成的
Wow, you already replaced the MOSFETs and did a reflow of the CPU, HANA chip?
Please check again if this is the correct solution for your problem depending on the number of red lights blinking and the error code.
Maybe some else here has an alternative solution?
完成的
添加一条评论
Loose wire at one of the connectors.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
louiserom70 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 574
