跳转到主内容
2003年10月,iBook G4 取代 iBook G3 成为苹果的消费级笔记本电脑产品。iBook G4 提供12英寸和14英寸机型,最后更新于2005年。
Why can't I defrag my iBook G4?
As a graphic designer I'm used to work with large files which I backup every time I finish a project. Usually I use iDefrag to defrag my iBook succesfully, but now it keeps giving me the folowing error:
Unable to open volume;HFS errors:
hfs_journal.c:92 (from 0x17318):
(12) The journal header seems incorrect
Is there any way to fix the problem?
Should I use another software?
Thanks and greetings!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sounds like you may have developed some bad blocks. I would backup what I could using Time Machine and reformat the drive using the write zero's option to spot the bad blocks and isolate them. I use TechTools Pro for defraging files and optimizing the volume: http://www.micromat.com/
Hope this solves your problem.
这个答案有帮助吗?
得分 2
1条评论:
Agreed +
完成的
添加一条评论
The chances are more to have bad blocks in drive. In such situations, one should first repair the files with disk utility or any other application. After the fix if you are getting the same error then try other tool for defragmenting Mac.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Victor Fonck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,086
