跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Can someone recover data from a smashed iPhone?
I have a iPhone 6plus that was driven over, completely destroyed! There is no throwing a new screen on it. However the internal components seem mostly intact. Can the memory be put into a dummy phone to recover pictures?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
joey, not unless you try your logic board out in a new case. You are of course going to run into numerous issues including your touch ID fingerprint scanner unless you can salvage the original button. There is no way to transfer the memory IC's to a dummy phone.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Difficult to say without seeing it. You potentially could get this back to working, the logic board that is. My advice is to plug it into iTunes, and see what it says, first
这个答案有帮助吗?
得分 3
2条评论:
There is no point connecting to itunes with a smashed iphone. The phone needs to be unlocked to sync.
完成的
Or to save all the info. If you where signed into icloud you might be able to sign in on your new phone to the same account
完成的
添加一条评论
Yeah would need to see a picture, but if you have a passcode on your phone, you will not be able to access the data, until you put in the passcode on the phone and trust the computer. If you plug into iTunes and hear the tones that's it's connected that would be good. Maybe you could find a repair place in your area to see if they could put on a screen or a broken screen for a few bucks just so you can get your data. If you need some help let me know
这个答案有帮助吗?
得分 0
添加一条评论
You should check your iTunes or iCloud backup first, and then if that doesn't help, use a data recovery tool to have a try.
这个答案有帮助吗?
得分 0
2条评论:
Check your itunes or iCloud backup firstly when encounter data loss.
完成的
My iTunes won’t unstall or do update Apple say it micro sifts issue. So they did all they could n iTunes claim it Microsoft. Neither did anything to get this resolved so can’t use iTunes at all
完成的
添加一条评论
It is possible to extract data of your smashed phone, if you have been constantly backing up your iPhone to iCloud, then you can restore your smashed iPhone data from iCloud backup.
The same things goes with iTunes backup. If you have kept the backup of your iPhone to iTunes then you can restore data from iTunes backup.
However, if you do not have any backup and as you said that the internal components are mostly seems intact, then you can also use third party iPhone Data Recovery software such software are specifically designed to retrieve data from smashed iPhone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joey 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 12
总计 23,055
