跳转到主内容
加入维修社区 - 创建账户
Motorola 于 2004 年 11 月发布了这款独立线缆调制解调器,用户可以通过以太网或 USB 连接互联网。它的前面板配备了 LED 指示灯,设备顶部设有一个待机按钮。
Why are all LEDs flashing?
All LEDs are flashing on my modem and modem does not work. Is there a repair procedure?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I had 2 problems with this modem (SBG6580). Initially it would turn on and all lights would be on and it wouldn't boot. Then a day later the modem lights would blink every other second. I finally found that the problem was the power supply. Replaced it with a new 12v (1.5a) power supply and havent had any issues. Good luck!
这个答案有帮助吗?
得分 2
2条评论:
Hurray, same problem, same fix!
Thanks! David
由完成的 分享
Brand new MB8611 showed same symptoms, top four LEDs flashing, LAN LED off despite being connected to router. Swapped in a good 12V power supply and everything started working. Big thanks!
由完成的 分享
添加一条评论
Maybe you need to run a router-reset or just a simple edit on the router's page.
for a quick solution...
Depending on the model, usually you should follow some basic steps:
1.
Turn off the router.
2.
a. Check for the reset button;
b. Use a bobby-pin or a matchstick and keep it press
3. Power the router while keeping the reset button pressed (5-10 seconds depending on the manufacturer).
4. All the led's should light up and stay lit; after 5-10 seconds, after releasing the reset you should have a factory reset router.
OS
这个答案有帮助吗?
得分 0
添加一条评论
Check that the power supply delivers 12v under load.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mdavi1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 41
总计 15,826
