跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Apologies: Yet another LCD/backlight question!
Ok so the Macbook we've had since '06 is great. Its taken a pretty rough beating over the years through many hours of use (sometimes 24h+!) but is still going strong.
Except the backlight is now non existent. Always trying to find the 'sweet spot', even this doesn't work sometimes.
Is it possible to change the inverter AND cable using the method shown in this link?
http://www.screentekinc.com/lcd-removal-...
I know there is the other method of dismantling the whole bottom case, but I don't want to jump into that if I don't have to.
I intend to check the cables before I attempt to replace anything, but I'm guessing it's the cable pinching on the hinges or a loose connection. If not, maybe replace the inverter cable, then try the inverter.
Thanks for this site people, It's a godsend! Keep up the good work :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Here's the answer I got to just about the same problem. It's has since saved me a lot of time: Replacing the inverter board charges
这个答案有帮助吗?
得分 3
2条评论:
完成的
完成的
添加一条评论
You can obviously change out the inverter by following the steps shown in the link. You will not be able to change out any cables, though, without disassembling the base. You should still look through the ifixit guide for replacing the LCD panel, especially starting at page 13 where they take apart the screen itself.
这个答案有帮助吗?
得分 0
1条评论:
Yea, I tried to check out the inverter using the method above (with just one laptop) by memory. Got stuck on the clutch/hinge cover... couldn't get it off! gave up lol... Think next time I will try the Ifixit method, and replace LCD bezel + clips while i'm at it.
完成的
添加一条评论
添加你的答案
Biggles 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 855
