跳转到主内容
Why won't topcases for other 14" G4 iBooks work on this machine?
Hi! I encountered x2 of this machine, which is the highest-end 14" iBook, with integrated Airport Extreme and BlueTooth. They both work, however the topcases are mangled and not presentable (although functionally the topcases do work). No problem, I thought, as I replaced them with other topcases from similar models, only to find that the trackpad did not work at all when I tried topcases for 1.33GHZ 14" iBooks on the 1.42GHZ machines. The topcases look the same, the connectors are identical and connect fine, and they power up the machine, only the trackpad is dead. I've tried about x10 various topcases, and only the two I have that are specifically for the 1.42GHZ machine will work. Anyone know why, or how to rectify this? It's a shame that I have two high-end iBooks that work great, but that aren't going to be usable simply because I don't have an absolute 100% match on the topcase. Unfortunately the electronics related to the trackpad can't be moved, due to being embedded in the plastic of the topcase. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
IIRC, the 1.42 iBook is the only iBook that supported two finger scrolling, which would explain why the older trackpads don't work on the newer machine.
这个答案有帮助吗?
得分 3
1条评论:
Thanks, that makes sense! I just Googled and verified it. Too bad they didn't make the trackpad look a little different inside, so as not to make the situation confusing!
完成的
添加一条评论
最有帮助的答案
I know you'd like to hear that something else will work, but who knows more about these machines than you do? Sometimes you just have to use the right part ;-)
这个答案有帮助吗?
得分 3
1条评论:
Hah, well, yeah, it may just be a matter of the right part, but it's weird, cuz the plug is the same, and it looks the same, so you'd think it would work. All other iBook topcases work with other models when the connectors match. It's not like the 1.42GHZ trackpad had a special feature like multitouch or something, and therefore needed a special trackpad (that I know of, anyway). Ah well, you're probably right. It's just a bummer I can't use these 37 other topcases I have here that by all appearances should work. :-(
完成的
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 737
