跳转到主内容
HMDX Jam HX-P230 is a wireless Bluetooth speaker manufactured and released by the HMDX Company in 2012. Also known as JAM classic portable speaker.
37 个问题 查看全部
HMDX Jam's micro usb charging port not working
So I'm trying to see if its possible to change or even fix the charging port on the speaker mine will no longer take a charge and the pins look a little bent inside of the unit..not sure if its feasible to even repair or change it..thanks anyways
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Alexander, biggest issue will be to find the right port. If you can find a replacement port, unsolder the old one and replace with a new one. Using this guide you can actual get to the connector. You will need some port in order to charge the battery. You can always rig it by using a charging cable, cut the micro USB end off and solder the wires to the contacts on the port. Not perfect but it would work and still better than a landfill.
这个答案有帮助吗?
得分 1
1条评论:
Email them and tell them it's a horrible design...I've gotten 3 since cause every one is crap..After about 10 time putting charger in the little pieces the charger hooks to bends...Now I've asked for different one but they will send another..Now I keep the charger in at all times..What I meant to say they will not send another type of speaker
完成的
添加一条评论
添加你的答案
Alexander 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 40
总计 4,406
