跳转到主内容
加入维修社区 - 创建账户
2011 年推出的东芝笔记本电脑。该型号配备 Celeron、Pentium、Core i3、Core i5 或 Core i7 处理器。
How do you replace a dvd drive
how do you replace a dvd drive.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here is a link to a video which shows how to completely dis-assemble a Toshiba L755.
You need only watch the video for about the first 1:30 minutes to see what is necessary to remove the DVD drive. You do not need to remove everything that is shown being removed up to that point in the video. It is not necessary for what you have to do.
You need to do only the following to remove / install a DVD drive.
1. Ensure that the laptop is off
2. Remove the battery (shown 2 - 4 seconds into the video).
3. Remove the 3 screws from the middle compartment lid on the back (shown 38 - 48 seconds into the video), and take off the lid . - Put the screws in a container so you do not lose them!
4. Do NOT undo / remove anything from the compartment EXCEPT the two memory modules (59 secs - 1:03 minutes into the video). Removing the memory modules, gives better access to the back of the DVD drive. You do not have to remove them if you feel that you can easily access the screws and catch holding the DVD drive.
5. Remove the 2 screws (put in a separate container, so as to not confuse them with the other screws) holding the DVD drive (1:03 - 1:10 minutes into video), slip the rear catch (1:19) and pull out the drive (all done by 1:24 minutes into video).
6. Installing your new DVD drive,(Check that it is a suitable replacement) is just reversing the procedure you have just done.
Note: The memory modules have an offset slot in the contact edge, so they will only fit in, in one direction when you install them.
https://www.youtube.com/watch?v=L8rxs5Th...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
maryks37 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 484
