跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Keeping the Touch ID function?
Hi to All!
I was given an iPhone 5s that had fallen into a toilet. I was able to bring it back to life again. However, the person who performed "first aid" tore the flex cable of the home button.
Here is my question: Is there a way to keep the touch ID function...
a) by replacing the flex cable (and continue to use the original home button)? I did some research on that topic but without any success.
b) by buying an original Apple home button flex cable unit?
Thanks for any help you can offer.
Steffen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Steffen the only way to get this done is by having Apple do the repair. The touch ID etc. is paired with the processor etc. and most likely will have to be programmed through Apple to be made functional. Even if you want to continue to use it without the touch ID, a later upgrade will most likely result in an error 53 and brick the device.
这个答案有帮助吗?
得分 2
1条评论:
Thanks a lot for your answer. That helps and saves me further research (and time). I knew about the deactivation of the ID touch when I replace the entire unit of home button and flex cable. However, I did not know about the issue with a later upgrade. Thanks a gain!
完成的
添加一条评论
添加你的答案
Steffen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 96
