跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
Temporary repair for s4 using s3 screen and digitiser
Is it possible to use the S3 screen and digitizer to temporarily repair the S4 due to a broken screen and digitizer?
I have a working S3 and a broken digitizer on my S4. I have data i wish to retrieve from the S4 but it is locked with a passcode and since the screen wont function i cannot input the code to unlock it. Therefore i thought i may be able to economise and use the S3 screen to unlock the S4 to get the data off it. I am not interested in salvaging the S4, i just want the data. Oh and it's an i9505 on the S4.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi,
Since your S4 still "works"(i.e. you can see the screen but the touch doesn't work-is that right?), you should be able to connect a mouse via an OTG cable (be sure to get the right one they are available on Ebay - look for OTG for Samsung S4) and use that to move around your screen and enter the passcode. Not certain how it goes with pattern locks though.
Once your phone is unlocked, quickly switch out the usb OTG cable to another pc to phone usb cable and connect it to a pc and see if the computer can see and access it. Locate the data you wish to get. As long as you can get in and start a transfer you will be ok, even if it locks the transfer will finish. You can also press the volume button to keep the screen active so you know it stays unlocked. Just keep an eye on a timer or something and remember that it usually locks (I think) after 60 seconds of no input.
I hope this helps.
这个答案有帮助吗?
得分 4
6条评论:
Afraid not. Screen is completely black so can't see anything. The phone is still receiving calls and messages, but i can't answer them as the digitizer itself is broken. (I can see it's cracked). So, no touch and no image.
I tried connecting to the computer using kies but since it's locked i can't get it to connect. That's why i thought if the S3 had the same physical connection, even though in a different location on the digitizer, i may get past the lock screen and gain access.
I'm not trying to put it together to get a useable working phone, just to unlock it really. Thanks though.
完成的
Hi Phil,
Do not wish to labour the point, but thought this link has interesting info re your problem, if you have the time and inclination that is. One interesting method described was to connect a keyboard via OTG then key in the numbers to unlock. Anyway for what it is worth...
http://forums.androidcentral.com/general...
完成的
Thanks Jayeff. I feel a trip to Maplins is in order. I'll let you know if it works for me. I like the keyboard idea. Seems so simple.
完成的
Strangely, i can get it to work for the S3, but not for the S4. The connector still works as it can charge and connect to the computer (just can't access as locked). I've tried both mouse and keyboard options, but no luck! Guess what i really need is a shop to use a new screen to unlock the key lock on the phone and then give it back to me with the broken one. Not sure anyone would be open to that though.
完成的
Hi Phil,
Bad luck. Don't suppose you have a registered account with Samsung for your S4 ? Because according to this link you can remotely unlock your phone using their website - see method 3 http://joyofandroid.com/unlock-android-d...
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Phil 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 2,310
