跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab Pro 8.4 是三星生产的一款基于 Android 系统的平板电脑,于 2014 年 1 月发布。
charging port does not work
The pin inside the charging port seem to be broken.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
i think you just answer your own question.
这个答案有帮助吗?
得分 1
4条评论:
Well, not really. I was hoping for some advice on how to get access to the plug. I didn't find any repair videos on YouTube and no repair manuals
由完成的
Ok, that's a better question. If your problem is the port as you say, you have to swap charging flex cable which is pretty simple compared to Samsung normal approach of soldering port to the motherboard.
Here is a link how to open the tablet
https://www.youtube.com/watch?v=lEVFYQks... (0:25 - 2:20 time)
And here is link to buy DOCK CHARGING FLEX CABLE http://www.parts4repair.com/dock-chargin...
When removing old port from the device be carefull not to damage pinheads in the process. Hope this was more helpfull and gives you enough information to proceed with the repair. Good luck.
由完成的
Thanks a lot. I am afraid my first question went into cyberspace in an amputated version.
由完成的
does the port pull out or do you have to remove the plastic on top of it
由完成的
添加一条评论
Is there instructions on how to remove the charging port or flex cable?
这个答案有帮助吗?
得分 1
2条评论:
yes is understad
由完成的
was good and wounderfull
由完成的
添加一条评论
添加你的答案
terje 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,166
