跳转到主内容
加入维修社区 - 创建账户
BlackBerry Bold 9900 是一款带有物理全键盘和触控屏的手机。
Phone wont switch on
Hello have a phone problem ,it doesn't switch on the screen is black even after I changed batteries===
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
5条评论:
We seem to be having the same problem, mine only flashes red when u try to put it on but yet remains blank
由完成的
same problem
由完成的
My blackberry bold 9900 won't turn on I tried a new battery and it only worked for an hour or 2,then I charged the two batteries else where it also for an hour or two . when plug in the charger the led light turns red and u only see battery charging sign that's all.
由完成的
Same problem
由完成的
Phon chargeing problam
由完成的
添加一条评论
1个答案
Hello geraldmtshali,
  • install blackberry manager
  • Connect the phone via m.USB cable
  • Update the firmware if available otherwise you can do the repair the phone by blackberry manager
  • Fallow the instruction
Hope above steps will help you to fix your BB
这个答案有帮助吗?
得分 0
4条评论:
I removed my battery out of my phone, then when I put it back in again which was about 1 hour later it wouldn't turn back on, it has no LED flashing at all, I've tried plugging it into the charger and nothing happens and plugged it into the laptop that also done nothing. The laptop doesn't even realised I've plugged it in.
Can anyone help?
由完成的
Hello shuvo, does BB manager detects your phone ?
由完成的
no brother its not :(
由完成的
Then it should be hardware fault. simply you can check the micro USB connector either it physically damaged.
由完成的
添加一条评论
添加你的答案
geraldmtshali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 6,055
