跳转到主内容
加入维修社区 - 创建账户
Xperia Z1 Compact 是索尼推出的高端拍照手机。它与 Xperia Z1 型号类似,但体积更小、价格更低。其主要特色是搭载了一枚 2070 万像素的传感器。发布时有白色、黑色、粉色和青柠色可选。 可通过型号(D5503)识别该设备。
How to clean dust from camera?
Hi guys!
I want to ask if it's possible to clean the dust from my phone's camera. I don't even know how it got dusty :( (if you need I'll post pics)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Maybe it is not the dust from camera but on the camera lens? No matter which one, if you want to clean the dust, you may need to remove the back cover firstly, and then use the soft cloth to clean dust.
完成的
添加一条评论
2个答案
use a sharp object like blade( insert it to the any edge of the round lens cover) to pull the lens cover (be careful with that) and blow the dust out (use ur mouth to blow) or a soft cloth
这个答案有帮助吗?
得分 0
2条评论:
Well I'm a bit afraid of your method I think I'll just pass this :s
完成的
it is sooo simple and easy you just have to be steady are careful...
if you get the same phone i will demonstrate of for you with VIDEO
完成的
添加一条评论
If you want clear the rear camera dust, you need remove the back cover. The first time the phone is disassembled, it needs some tools and operations.
This Sony Xperia Z1 Teardown can help you disassembly the Xperia Z1.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
domohpi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 2,610
