跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Why is my MacBook occasionally restarts with a kernel panic?
Hello,
I was dropped My macbook pro retina short while ago. It restarts randomly with a kernel panic occasionally. Screen edge is scratched and blacks at that edge is brightened some...
Macbook is not stable now, i don't want lose my work because that unexpected kernel panic problem. What should i do? Is screen can cause this problem?
I am using OSX 10.9.5 now. I ignored updates after this version because it's stable with my audio engineering softwares... Is an update also can help me?
Thanks for help already now...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
I solved my problem... Solution is so simple... I opened my macbook and checked the connector between logic board and screen... It was not well placed. I think after i dropped macbook that connector was taken out. So i replaced this connector and kernel panic problem went away. If someone who encounters a problem like that it is worth a try...
Thank you for all your concern.
这个答案有帮助吗?
得分 1
1条评论:
how did you do it though?
完成的
添加一条评论
最有帮助的答案
First, keep your security updates done. You don't have to upgrade the system. Kernel Panics can be hardware or software related. Keep an external backup of your data at all times. Just plug in an external hard drive and it will ask if you want to use it for a Time Machine backup. Install a good anti-virus such as Symantec. Apple is now a target because of their success, no one cares about Bill Gates anymore.
To see if something you added is causing the problem start up in Safe Mode by holding down the Shift key on start up.
这个答案有帮助吗?
得分 3
4条评论:
I'm using Bootcamp and Windows 7 is installed as second OS. I having this problem on Windows too. All security updates are done and i'm using Avast Mac Security 2015.
I think there is a problem which originated from hardware rather than software. What makes me think like that is this kernel panic started right after i dropped my macbook. Is screen replacement can be solution for this case? What is your opinion?
Thanks for your concern.
完成的
If Tom suggestion is over your head, I'd take it to a Apple Store or ASP and see what they would charge for a Flat Rate Repair as you may have logic board issues.
完成的
Hi,
My MacbookPro 15inch late 2013 stopped booting up because of kernel panics. And when I took it to the service center they told me that the logic board needs to be replaced which would cost me around $700. No damage no software failure.. Just out of the blue it started this problem. I have started to question the quality of Apple products now.
Thanks!
完成的
Call 1-800-MYAPPLE. Ask about a "flat rate depot repair". It should be $357 including shipping and tax.
完成的
添加一条评论
Most likely cracked solder joints under the chips, causing system instability.
You can find the exact module of failure by tracing the panic dumps.
这个答案有帮助吗?
得分 3
1条评论:
Thanks a lot. I'll try...
完成的
添加一条评论
添加你的答案
Tevfik Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 2,139
