How do I fix the broken charge port?
Will not charge. The inside of the charger is broken.
I don't think the charge port is USB, it uses a mini cord that should slip over the contact.
这个答案有帮助吗?
i think you need to resolder that USB port
go to ifixit youtube channel and check out resolder of USB port on SGS3, on SGT4 it should be the same
i don't think SGT4 has USB port on doughterboard (so you just replace that little piece )
resoldering that without equipment is nearly impossible
you can buy tools and DIY but it's gonna cost you a bit
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 803
1条评论
I had the same problem with device purchased May 2015. I just received replacement unit 2 days ago and again have same problem!
由 troyerdd 完成的
