跳转到主内容
加入维修社区 - 创建账户
Dell Venue 11 Pro 是一款专为商务打造的灵活平板电脑。它配备了许多面向工作的特性,包括 Windows 8.1 系统、可拆卸电池以及多种扩展坞解决方案。
will not charge. How to fix it?
I've connected the battery charger to the tablet and nothing happens, white light that indicates chaging does not come on the tablet. When I connect the charging cable to the travel keyboard connector the light comes on indicating that it is charging. How can I get the tablet to charge?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
Check to see if the light on the power supply goes out when you plug it into the tablet. If so the problem may be the USB charging port board may need replacing. If you open the tablet it is a good idea to replace the real time clock battery if this has not been done.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Char1 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 36
总计 2,815
