跳转到主内容
加入维修社区 - 创建账户
Micromax Canvas 2 Plus A110Q 是 Micromax Mobile 于 2013 年 5 月推出的双卡 Android 智能手机。
facing OS system issue
I have a Micromax A110Q Canvas 2 Plus phone whenever I start the phone the canvas word comes on the screen as if it is starting but it gets stuck to that only & my phone doesn't start. The display remains the same i.e. canvas written on the screen. nothing happens after this.
Kindly Help.
Regards,
Ratan Singh.
singh.ratan012@gmail.com
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I have done the same but nothing changes still whenever I switch on my phone screen comes p by writing canvas on it & after that it gets stuck nothing happens later to this.
由完成的
Hi,
I found this link which may be of interest to you. http://forum.droidarena.in/Thread-How-to... First he states that you press 3 keys (power + vol up + vol down) to hard reset. Different to what I have found (and you as well) elsewhere. Maybe you could try that before deciding IF you want to try his other option.
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
You need to hard reset your phone.
Before you do this make sure that the battery is fully charged.
Warning : A hard reset will restore your phone to factory default. You will lose all downloaded apps and user data!
To perform a hard reset do the following:
1.Turn off your phone
2. Press and hold the Volume Up + Power button (both together) until you see Recovery mode.
3. Release both buttons.
4. Select option "wipe data/factory reset" from the menu.
(To scroll options use Volume buttons, and to confirm press Volume Up key for 3 seconds).
5. Then confirm "yes" by Volume Up.
6. In the end accept (confirm with Volume Up key) operation "reboot system now"
The phone should now reset, be patient it takes a few minutes.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Rats 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 14
总计 353
