跳转到主内容
加入维修社区 - 创建账户
DualShock 2 模拟控制器随 PlayStation 2 一起推出,除了螺丝位置等细微的外观变化外,与前代几乎没有区别。
Left trigger not working
I took apart the controller to see and put it back together to see if maybe the button was just loose but that didn't seem to fix the issue. What would you suggest my next move be? I'm trying not to purchase a new one
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
The bottom triggers are tricky to reassemble. You probably didn't do it right. You need to feel the popping of the button. If it doesn't feel like there is two states, then you need to reassemble it.
由完成的 分享
添加一条评论
4个答案
已选择的解决方案
If your comfortable taking it apart again clean everything with isopropal alcohol. Sweat from your hands gets into the controller and gums up the functionality of the controller. If the feel of the button is off dead feeling it may be plan broke but if it still feels right a good cleaning can do wonders
DualShock 2 拆解
Hope this helps
这个答案有帮助吗?
得分 7
1条评论:
Thanks! I'll give it a try!
由完成的 分享
添加一条评论
Is the L1 button not working or the L2? If the L2 button is not working, you can pop it off the assembled controller with a Spudger. When you do that, you should see the rubber buttons that the L2 button pushes down on.
Realign the rubber button and rubber strip into the plastic channel and then put the hard L2 button back on (pinch the sides of the button gently and then insert them back into the assembled controller, they should snap in place).
After that, try the L2 button; you should hear a clicking sound.
这个答案有帮助吗?
得分 3
添加一条评论
It sounds like you wore out your controller. You could repair it or just get another controller. I wouldn’t mess with it, I would get another controller.
这个答案有帮助吗?
得分 0
添加一条评论
the connection port of my controller got one pin missing…… what should I do…. please help !!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricardo Martinez 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 20
过去 30 天: 89
总计 16,447
