跳转到主内容
加入维修社区 - 创建账户
Macintosh LC II 发布于 1991 年,是一款低成本彩色 Macintosh 电脑。它接替了 Macintosh LC,随后被 Macintosh LC III 取代,这些机型均采用了“披萨盒”(Pizza Box)式的机箱设计。
Can't boot up my computer
I can't boot up my Macintosh LC II. It keeps trying then it stops with a white screen on the monitor. There are no 'faces' appearing on the screen when it tries to boot. Now after umpteenth times I now get only a dark screen. Interestingley in one of the boot tries I was able to get my open file page but with a frozen cursor. After a few minutes the page disappeared with only a white screen again re-appearing. Can this kind of malfunction be repaired?
Update
I found the battery, Thanks, Ralph
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Fortunately, I found an easy way of fixing my problem. With the intention of removing the hard disk, I first disconnected the multi-pin cable to it, but then decided to remove it for the next day instead. I re-connected the cable back to the hard disk. Lo and behold when I switched on the power, the computer booted up in normal operation.
Presumably, the problem was an oxidation film built-up on the pin contact(s) over the past 2 decades on my Macintosh LC II. Disconnecting and re-connecting the pins evidently abraded enough of the film surface to again make good ohmic contact.
由完成的
Oh, by the way I want to thank both Marian and Mayer for your interest in helping me out. Ralph
由完成的
添加一条评论
2个答案
已选择的解决方案
Replace the 3.6 volt AA battery and see if the problem persists.
这个答案有帮助吗?
得分 4
5条评论:
Thanks Mayer for the battery replacement suggestion. I've taken the cover lid off, i can't find the battery. Where is it located? Thanks. Ralph
由完成的
由完成的
Here's the PRAM battery you need--just look for it. Good luck. Ralph
http://eshop.macsales.com/item/Newer%20T...
由完成的
It should have a small black plastic cover with a slot in it that pulls off, totally useless part. Just note the positive and negative markings.
由完成的
I replaced the 3.6 V battery, the LC II still does not boot up. Any further suggestions? Thanks. Ralph
由完成的
添加一条评论
Hy, Ralph!
How's your LC? Did you repair it?
I've just repaired mine. The power supply was KO. I found one (not genuine) with +/-5V&+12V from an old computer.
The battery keeps your settings and should not be a condition for starting. (At least at my LC).
All the best!
Marian
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Ralph 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 6,158
