跳转到主内容
加入维修社区 - 创建账户
亚马逊 (Amazon) 开发的一款便携式电子阅读器。维修过程简单直接,仅需撬具和螺丝刀即可完成。
Screen stuck on sleep mode screen
Screen is stuck on page which come up when sleeping and book I was ready when tapping screen doesn't come up. I can not switch the kindle of either ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Try the following to reset your Kindle Paperwhite.
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart.
If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
这个答案有帮助吗?
得分 2
3条评论:
I held the power button until my finger went numb (several times) still nothing.
由完成的
Me too !!! What to try next?
由完成的
If it still doesn't work, you should keep pressing it, let your fingers rest and then, maybe, it'll show the problem. Mine did that and the screen suddenly went white and it warned me that the battery was dead. Sometimes, the battery is the problem. If your battery is dead, you will not be able to restart, nor turn "on" the Kindle.
由完成的
添加一条评论
Plug it in to charge, then hold the power button.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
nina73jones 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 6,718
