跳转到主内容
加入维修社区 - 创建账户
2013 年 9 月发布,型号为 T100T。这是一款二合一便携设备,搭载英特尔® Atom™ 四核处理器和 2GB 内存。
How to reset BIOS?
In Asus T100 is there BIOS battery?
Or do I just remove battery for several minutes?
Or maybe anyone have Rescue Password for 2012/01/01?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 23
56条评论
Did you found a rescue password for 2012/01/01??? Please, let me know.
由完成的 分享
The ASUS rescue password for 2012/01/01 is ABLDABLA (make sure you use caps).
由完成的 分享
please password' not working abldabla
由完成的 分享
14/01/2016 Please
由完成的 分享
2012/08/10 please
由完成的 分享
显示更多的51条评论
添加一条评论
8个答案
已选择的解决方案
Nvm, I guessed password.
It was "asdfmovie" xDDD
But thanks for trying.
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
Try this rescue password: ABLDABLA
Let me know if it works :-)
这个答案有帮助吗?
得分 11
24条评论:
Haha LOVE ASDF Movie! Nice password ;-)
由完成的 分享
This password don´t work for me. Please, I need a password for 2012/01/01 that works!
由完成的 分享
please help i have the same problem when i start my Asus nx500j laptop it asks for bios password
由完成的 分享
I need a password for 2016/02/16 or 2016/02/17. Help please!
由完成的 分享
Why would anybody so dumb as to put a password on the BIOS?
由完成的 分享
显示更多的19条评论
添加一条评论
Hi Idav2k9,
Because it prevents other people from changing the configuration of your PC, if you happen to leave it unattended for a short time, like if you are in a library for instance.
There are some people who think that it is funny to do this.
Once bitten......
这个答案有帮助吗?
得分 2
1条评论:
Pls all the passwords are not working for me,pls help me
由完成的 分享
添加一条评论
Assuming you are locked out of the OS as well and can not simply use a third party tool or change your date to use a recovery password, then use this method. It is actually easier than hassling with all that IMO.
== Using a Backdoor Password ==
Here is a list of American Megatrends Inc. backdoors. A password in BIOS which always works irrespective of what password you have set in BIOS. Its a master password which is used for testing and troubleshooting purposes.
A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
This will allow you to bypass the password.
For most systems you can get the list for your use by inputting the incorrect password 3 times. You should see a message that reads "System Disabled" followed by a number. Go to BIOS-PW.org and input that number to get the password list for all manufacturers that match that checksum you entered. These will always work as long as the password you put in matches the checksum the system gave you, because that will be the same checksum generated by your password.
Also, don’t worry about the system disabled message because it’s just a scare tactic. All you have to do is turn off the computer and turn it back on and you’ll be able to enter the BIOS password again without any issue. This method works for almost any computer so instead of burying it here I am going to check to see if there is a guide write up for it, and if not create one for easier access.
这个答案有帮助吗?
得分 2
1条评论:
It doesn't work, never apearse the message of system disables message
由完成的 分享
添加一条评论
Go to Windows and set dat to 2002/1/2 (US date format)
reboot and when it promt for password hit alt+r for recovery password mode
type in pass ALAA4ABA
这个答案有帮助吗?
得分 1
2条评论:
I need a Bios rescue for Asus Tablet R+Alt = 2016/03/25.
Could you please give me the rescue password?
由完成的 分享
It's for my Asus t100ta Transformer tablet (so, I can't get too the closing battery
由完成的 分享
添加一条评论
When I hit alt+r, my bios date keeps changing. How do I find the right password?
这个答案有帮助吗?
得分 0
1条评论:
need rescue date for my Asus X441N laptop
由完成的 分享
添加一条评论
I and thanks for help, but on T100H with 2012/01/01 don’t work ? Why ???
Don’t work with caps, without caps, on screen, on keyboard, on external keyboard…
Please help
这个答案有帮助吗?
得分 0
3条评论:
I try ABLDABLA / qwerty and azerty (I'm French)
由完成的 分享
could you solve it?
由完成的 分享
Please tell me if you ever figured out the bios password to T100h I'm really needing it
由完成的 分享
添加一条评论
I have this asus n3700-a/k20ce model and there is no jumper to clear cmos. Pressing alt+r wont work. I have taken the battery out for more than 24hours even tried up to 2 days. Shorted the negative and positive of the battery. Even stripping all the cables out but no luck at all. This is frustrating. Even asus couldnt give a good solution. Maybe next time before u buy an asus mobo.. better check whether it havr a cmos reset function or not.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 62
总计 42,159
