跳转到主内容
加入维修社区 - 创建账户
Asus Eee PC 900 笔记本电脑是一款重量为 2 磅(约 0.9 公斤)、尺寸为 8.8 英寸 x 6.5 英寸 x 1.4 英寸(约 22.4 厘米 x 16.5 厘米 x 3.6 厘米)的上网本,有黑色和白色可选。
Error message of reboot and select proper boot device
My laptop was working fine then when I turned it on I got reboot and select proper boot device or insert boot media in selected boot device and press a key,
by chance it booted properly once so I put it into sleep mode and when I got home to put a usb stick in so I could transfer my files it was back to reboot and select proper boot device or insert boot media in selected boot device and press a key,
Since it reset itself once I am hoping there is an easy fix. on this site there is 2 pieces of equipment, the ram and the hardrive. it is the hardrive that is malfunction right? If I switch it out would I be able to get my documents? I am a writer and my work is on it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
is there by chance a CD in the optical drive it may be trying to boot from that if the cd is set as primary
由完成的
添加一条评论
1个答案
In my experience, you are probably right. It is probably you hard drive malfunctioning.
It depends how far gone your drive is, in regards to how easy it will be to recover the data.
In many cases, removing the hard drive and connecting to another computer as an external drive will allow access to the drive.
You can get an USB to IDE/SATA cable for around $20 from Newegg. They are easy to use, and, if the drive is still somewhat functional, it will be like taking information off a thumb drive.
If the drive is too far gone, you may need to pay a professional, but normally the cables do the trick.
You will probably need a new hard drive & operating system, if you want to continue using the computer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pauline 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 1,778
