跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 5 (又称 Note5) 是一款配备手写笔的平板手机,由三星制造,于 2015 年 8 月发布。
Replacing the front glass
I have the repair kit that came with my glass front. Do I have to take the phone apart to remove glass?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
if the glass gets damaged, the easier and safer solution is to replace the complete screen assembly since the glass, digitizer and LCD screen are bonded together tightly by the help of very strong adhesive, and it is very hard to separate neither of them for individuals. Yet it is possible to remove the glass from the LCD, as long as you have special tools as well as professional skill. Otherwise, it is better to replace the whole assembly rather than just the glass. Also, to replace the screen assembly asks for phone teardown, you need to remove the back cover and mid-frame firstly.
由完成的
添加一条评论
5个答案
已选择的解决方案
You don't need to take it completely apart but you need to disassemble it enough to unplug the LCD and Digitizer connectors
这个答案有帮助吗?
得分 1
3条评论:
that would be under the glass in the bottom or top?
由完成的
The LCD/Digitizer/Glass is all one piece. This solution is misleading.
由完成的
You will need to remove the back cover, the frame under the back cover, and then unplug the connectors. After that you can take off the LCD/Glass assembly
由完成的
添加一条评论
最有帮助的答案
You're screwed. Really really really really screwed. Not only are you really screwed but...... you are screwed as well
这个答案有帮助吗?
得分 2
添加一条评论
Did you just buy replacement glass? I don't believe it's possible to just replace the glass on the Note 5, i'd be extremely impressed if someone could.
This video covers a number of repairs including the screen:
https://www.youtube.com/watch?v=aQcbGNuI...
Edit: As mentioned in my original post, it's not possible as Matt highlighted below without specialised equipment. You need the full LCD/Digitizer/Glass replacement. I'd advise you to return the one you purchased via Amazon.
这个答案有帮助吗?
得分 1
6条评论:
Yes It was 14.99 on Amazon just the glass and tools for it.
由完成的
You are going to have to buy one that also includes LCD... The tools needed to do "glass only" repairs on the galaxy and galaxy note series cost a few thousand dollars. Unless you are doing it in mass quantities it is more financially beneficial to do LCD and Glass together or else you will be wasting a lot of time and glass.
由完成的
As mentioned in my original post, it's not possible as Matt highlighted without specialised equipment. You need the full LCD/Digitizer/Glass replacement. I'd advise you to return the one you purchased via Amazon.
由完成的
oh ic I have seen alot of phones that people replaced the glass note 4, I see people say just replace the whole thing b/c glass takes to long. I mean they wouldn't sell the glass if you couldn't do it right? this is what I got http://www.amazon.com/gp/product/B015ZIF...
由完成的
No doubt it's possible but extremely difficult without specialist equipment like a hot plate to remove the glued on glass. Without something like that it would be incredibly difficult to remove the glass without it damaging the digitizer.
由完成的
显示更多的1条评论
添加一条评论
Just to put in my 2 cents: a hot plate itself is around 100 dollars. I don't know what tools are necessary that would cost even one thousand but that aside, it is a very difficult repair. Do not attempt. I'd like to see the amazon link though.
这个答案有帮助吗?
得分 1
2条评论:
http://www.ebay.com/itm/like/17194721933...
Here's a cheap one for just iPhones
由完成的
I just got put in the whole full LCD/Digitizer/Glass replacement and im getting a black screen with blue light? did i get a non function replacement?
由完成的
添加一条评论
How much is it to replace a note 5 scream? I dropped my phone and the screen won't show is it just the glass? I also have a note 4 that just turns on and off what does that mean
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vinpan80 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 33,284
