跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
cycle light blinks but wont start
washer wont start, cycle light blinks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
patsy, from your description this is likely a bad door switch button. See if the door and the switch line up. You may also try to recall any of the last error codes by following these steps:
Select the DRAIN/SPIN cycle
Select NO SPIN
Press and hold the PREWASH option button for 5 deliberate seconds
The last stored failure code will be displayed for 4 seconds then the display will switch back to the normal selection mode. Let us know if you get any code.
这个答案有帮助吗?
得分 2
4条评论:
I did test and got no code.
完成的
patsy, then my first fix would be to check/replace the switch button.
完成的
that is exactly what is wrong with mine… what is a part number for that machine?
完成的
Hi @Dawna Austin
Search online for "(insert model number of washing machine) parts" to find suppliers of parts who have parts diagrams etc e.g. searspartsdirect.com or partselect.com to find the manufacturer's part number (not the supplier's part number) for the part that you want.
Then search online using the manufacturer's "part number only" to find suppliers that suit you.
完成的
添加一条评论
添加你的答案
patsy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,956
